33” tire rim width
Shoote
florida
tim
I have a 1987 4x4 short bed with the optional aluminum wheels. I believe they are 7” wide. Will 33 x12 tires be safe to install on these rims? I believe 32x11 will fit for sure but I would like to go bigger. Stock tire size for this truck is 31x10. Thanks in advance!
gmbellew
Kansas city
glen
suburban 1500
I run BFG 33x10.5r15 on those rims. I believe the 12in wide tires are too wide for the 7in rim width.
dvdswan
Port Orchard, WA
Dave
As a general rule, optimum width for tire/wheel combinations is 4". i.e. 8" rim with a 12" tire, 10" rim with a 14" tire. That being said. I've seen an 8" rim with a 14" wide tire. The tire looks squeezed and taller.
Auburn, Washington
You’re a little off there.
First using a hard dimension is not right.
Second in this case, 8” rim for a 12.50” tire would be about the absolute minimum without ballooning the tire.
.8-.9W is optimum. .7W is about the min acceptable.
Auburn, Washington
Need to be a little more sure about the rim width.
For wheeling I’d put a 12.50 on a 7” rim and run it. For street use, too narrow.
Technically, the rim is too narrow. But, an incredible amount of people have run a 12.5 tire on a 7 inch rim and it has worked fine.
Also, I've run a set of 15.5" width tires on an 8" wide rim before. I bought the tires used and they were on '94-ish F150 rims that were only 7" or 7.5" width.
75gmck25
Northern Virginia
Bruce
You might find a tire shop that can make a quick stock rim width measurement for you, just to verify what you have. They have a large set of calipers that just slips over the mounted tire and it gives them a measurement.
As an Amazon Associate we earn from qualifying purchases.
If they are the factory aluminum wheels, they are 7" wide. The large calipers will read from the outside of the beads and show ~7.5" wide.
backwoodsman
Idaho
GMC Suburban K1500
6.2L diesel
I'm surprised no one has mentioned that tire manufacturers specify a range of rim widths for each tire. It'll be on their website. The 33x12.5's I've checked specify a minimum 8" rim. It seems like a bad idea to deviate from the manufacturer's specs on something on which safety depends so heavily, except maybe for low-speed off-road use.
I usually use the narrowest wheel a tire specifies, because it pulls the sidewalls in a bit, which provides some protection from curbs or rocks.
Corncob
