2nd gen in 87
td87
CT
Trevor
V20
Hey everyone. I've got a 2nd gen 6bt mounted in my 87 1 ton. I'm using the dodge automatic and still gotta find an np205 29 spline. I bought a full donor truck so I wanted to use the dodge pcm, but I can't find any info online with wiring the pcm into my 87. As far as everything else related to the swap I've got it pretty much licked, it's just the wiring side of it that's holding me back. If anyone has ever done this or has any input on how I could go about wiring this, I'd appreciate it very much. Thank you
marks86
Latham, NY
Mark
12v Cummins
how are your going to mount a 29spline np205 to a dodge auto thats a 23spline
td87
CT
Trevor
V20
23 spline*
1987chevybad
New England
Alan
2nd gen dodge owner here.
PCM only controls
4th gear shift point (You could use toggle switches)
Torque converter lock up (You could use toggle switches)
Voltage regulator for Alternator (Install an external regulator off a first gen Dodge)
Grid heaters (You could use toggle switches)
It only takes 2 wires to run a cummins. Key hot for injection pump and a hot wire to the starter
RPMs for Tach
K10noob182
