1986 K10 Cutting off When Put in Gear
lbrown
Greenville NC
Luke
Hey y'all recently got a 86' k10 with the 350 700r4 and I've been having problems with it cutting off when put in gear recently. When I go to put it in any gear it shuts off immediately like I'm turning the key off, so far I have replaced fuel lines, mechanical fuel pump, new edelbrock 600cfm carb, properly adjusted the throttle cable, tv cable and the air/fuel mixture on the carb. I've checked most (don't want to say all) the vacuum lines and most of the wiring to ensure everything is getting proper power and vacuum lines are holding pressure. I've tried the NSS by replacing it and adjusting the original one to no avail (I have since put the original NSS back one). Truck starts up and Idles like a dream otherwise.
Issues I do know is the heater core is possibly bad, and had problems with the break light switch in the past.
As of today, the truck was going into gear and driving fine, parked it at the parts store where the problem arouse again and would cut off when placed into gear. Had it pulled to my house where it went back to going into gear like normal. Cut the truck off and when cut on if would not go into gear again. I am now stumped and lost.
I am seeing if anyone has a fix for this.
Forgive me if this is the wrong thread to post in, first time posting in a thread before.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
how much spark advance are you running at idle.
lbrown
Greenville NC
Luke
Off the top of my head I couldn't tell ya. When I first bought the truck I took it to a mechanic and had him do the timing and make sure the distributor was good as I do not have the best knowledge with distributors or timing yet.
zulander
Indiana
Edward
c30
Bad torque converter?
How did this start? Did it use to run correctly?
Auburn, Washington
^wouldnt a bad nss be no crank, not no run?
Sounds like a short. I’d be looking in the steering column.
Need more diagnostics from the owner though.
My first thought is that the torque converter has the lockup clutch frozen up or being commanded engaged... but since the OP only joined and created this thread, then hasn't been seen since, I bet he either figured it out himself or gave up on it.
lbrown
Greenville NC
Luke
Sorry for being gone, got caught up in work and put the truck off to the side for a little.
The torque converter seems to be fine. When I put the truck in neutral then start it, I can go into any gear just fine and drive around.
I did drop the steering column to look through the wires for a short, while it was dropped I started the truck. As it was running it picked the column up to where it would be normally and everything cut off immediately, not a stall out cut off. So there’s definitely a short of some sort there.
For timing I grabbed a timing like and it looks to be about 8-10 degrees at idle. Again not too technical with timing but I believe that’s where it should be.
I did find another forum saying the parking pawl could be getting stuck?
I did replace the NSS twice and the same symptoms were happening, so I doubt it’s that.
lbrown
Greenville NC
Luke
What do you mean by “being commanded engaged”? A little lost on that
Converter lockup is an electronic signal. If the converter lockup engages while it is sitting there at idle, it would be like dropping the clutch while engaged at idle in a manual car.
It sounds like your ignition switch might be out of whack or loose… not the key cylinder itself, but the actual switch at the base of the column.
lbrown
Greenville NC
Luke
I replaced the ignition switch awhile ago due to not having power going to the steering column at all to start the truck.
Could I have gotten a bad ignition switch?
Yes, very possible. It's also possible you didn't properly secure it, didn't plug it in all the way, it's come loose, etc...
The fact that it cuts off when you move the column points to something being out of whack there either with the switch or the wiring in the column.
thatgermanguy
