2001 YZ 250
Derick C.
Auburn WA
Derick
454/700r4
I do like those LT's
I plan on building an atv and dirtbike collection when my shop is done.
I've never owned an LT but I have built a few motors for friends.
I've had several 250r's and several tecate's, always been a honda a Kawi fan.
Buff71
Iowa
Shannon
On the bright side.... if you rebuild it, you know what you have. I have been caught it that trap and it sucks. Some people just shouldn't own tools. Wait maybe that was the problem lol
TravisB
Travis
Found a friend to patch my case, but the repair needs attention. The fix was too big and will be hit by the chain and sprocket but we are on the right track to getting back on two wheels.
TravisB
Travis
I have been slowly making a little progress on the bike. New bearings in the swingarm and linkage, frame getting cleaned up for paint, new crank and piston with the cylinder at the machine shop. This is going to be a new bike when/if we ever get finished.
WFO
Texas Panhandle
What is the Machine Shop doing to the cylinder? Maybe sleeving it.
I doubt if they can do the nicasil coating on the cylinder wall.
If not, I'd reccomend Millenium Technologies. They will weld in the deep gouges, grind it smooth, then apply the nicasil coating.
https://www.millennium-tech.net/serviceInfo.php?id=1
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Look into wiseco cranks online. Their pistons are fine, but the crank assemblies have a reputation for problems.
TravisB
Travis
Boring it 20 over to clean up the cylinder. I have no idea about nicasil coatings and never even asked.
TravisB
Travis
I have heard they had some issues with bearings in the past. I never heard anything about the cranks.
TravisB
Travis
You had me worried enough to call the machine shop and find out what the story was. Evidently my bike already has a steel sleeve in it so they are just boring it a bit to fit a .20 over piston.:shrug:
WFO
Texas Panhandle
I see. I was just making sure they weren't boring the factory cylinder wall. Unless sleeved, they haven't been boreable since the early 80s.
TravisB
Travis
You had me real worried since it was the factory size to begin with. With my normal luck the odds it had a new sleeve in there are so slim... I should probably go buy a lotto ticket.
TravisB
Travis
Well, I think I learned a lesson from the machine shop I thought I could trust. Went to get my cylinder and piston yesterday and they tell me they couldn't do what I wanted. They tried boring it and said it just flaked chrome off and wasn't going to work... Evidently looking at it, and my call to confirm they could do it weren't enough info for them to be able to tell that it was the original coating. So now it's proper screwed... I emailed Eric Gorr about a 295cc top end. If I am going to have to spend $400 on a new cylinder I might as well go for the big bore with all the fixings at $660.
I guess it didn't cost anything but an overbore two stroke piston. Glad I didn't take my truck engine down there. @Camar068 if you need machine work let me know. I can tell you who to avoid in Somerset.
Camar068
10 yrs Air Force
blast them away here so I'll have this to fall back on in the future. I'm not into ATV's and such....lol can't afford it, but I know a lot that are and would like to share this info with them. This will also show up on google searches as well as a warning to others. They will take a hit for it, may take a while, but they will.
Derick C.
Auburn WA
Derick
454/700r4
Sounds like it was a nikasil cylinder, I personally prefer a sleeved cylinder in my 2 strokes. Eric Gorr will do you right for sure.
TravisB
Travis
He's not replied to my email so I went ahead yesterday and ordered a new factory cylinder and piston kit. His website says they are not closed for Covid-19. His email attention says that he is or doesn't care so RockyMtn got my business. If he replies before I wear this cylinder out I might consider it next time.
alwaysbroken
