2000 z71
coreys87
newyork
corey
v1500
Looking at one tomarrow. Only catch is checkengine light is on for the vap system? Simple and cheap fix or what? Has 129k no rust thanks for any input. Its the 5.3
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
MIght have just been a loose gas cap. Newer stuff if you leave them loose once the emissions system will throw the light.
coreys87
newyork
corey
v1500
Said its been cleared and came back
Could be egr valve related :shrug:
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Tell 'em to meet you at Autozone w/it to let you get the code out of it. That might help you decide it's a risk you'll want to take.
swagger
old house in WV
Steve
350/SM-465/NP-205
That should be an easy fix, get them to knock a few bucks off the price for the light being on.
If you need I have GM Techline I can look that up for ya.
Steve
coreys87
newyork
corey
v1500
i have a diagnostic computer. so i guess ill go from there. thanks!
dreks95
Midland, Tx
Tim
I think the vent valve filter for the evap system gets full of mud and dirt, which causes the light to set, you can replace the valve and filter and leave it in the same spot, or you can relocate filter to underhood, where its less likely to see mud(hopefully)
robracing85
