2000 camaro ss
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Renewed my tags for $75 after a $25 inspection today. Went out in Feb. So they give me new 02/21 tags which I lose 4 months. Wtf!
Used to they give you that month that you renew them. Guess just another way they **** you. I'm legal now tho.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Yup, if there is a way to pry your wallet open they will find it.
Phuckers as recently as 5 or so years ago only took cash or checks at the courthouse.
WTF - in 2015 ?
Derick C.
Auburn WA
Derick
454/700r4
Well maybe in 5 more years you can put collector plates on it. I know that varies from state to state
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Checked up an down in the app and couldnt monitor the knock sensors. You can get active timing advance though. Sorry it wasnt much help.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Thanks for checking. Now, if you happen to know where that mystery vacuum tube goes...
Carb'ed Vortec 350
Who TF has a checkbook?
My dad is that old guy holdin up the line in the grocery store...writin a check. :) :emotions34:
Me, I have one. I like keeping USPS in business and pissing off the millennials when I pay my bills with them. :chair:
Carb'ed Vortec 350
That's what my wife would do too. Money would be tight so she had to wait to get the inspection to get the new sticker and/or plates. She mentioned the other day the she rode for free for many months over the years by not being able to get the inspection done right on time each year. She moved just before Texas went to the current system.
Crispy
Suburban V1500
I couldnt find it for the life of me. All I saw in the passenger side area were the light harnesses and horn. Did you trace it back to anything?
82sbshortbed
Fuckemall!!
SE Texas
Doug
Yeah I looked forever and came up empty too. Got me curious if you traded it back to anything too.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
You can't see it unless the bottom flap on the PS side is pulled down, but there is an oval shaped black plastic vaccum reservoir . My vents drop flow under WOT - I suspect this may be why. I'd hook it back up, but can only guess I will have to pull the battery tray to see if I can figure out where it plugs back in to.
Crispy
Suburban V1500
I didnt know they still used those on F bodies. Not surprised though. In any case, a little search turned this up. It might steer you in the right direction:
https://ls1tech.com/forums/generati...0732-98-pontiac-trans-am-vacuum-problems.html
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Yeah, the stuff up top is no issue, and I suspect that my little line goes up there as you can see a vacuum line wrapped in the wiring loom that comes down from it.
It's the in-between that is mysterious !! :eek:
Thanks for looking , though !! :waytogo:
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
It was hidden in the wiring loom - since I knew it was broken I went ahead and pulled it out.
Bought a short piece of 5/32nds vacuum hose, reconnected it, and you, that was the vent loss under throttle issue.
twitch1989
