1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Turned.
Now for ID.
Vbb199
Salisbury NC
Vince
Time to get to borin'!
Vbb199
Salisbury NC
Vince
Perfecto!
Vbb199
Salisbury NC
Vince
Easiest means of transfering a hole that you have no knowledge of its location is via transfer screws for anyone looking.
Vbb199
Salisbury NC
Vince
Redrill done.
Now to clean the threads and check fit.
Vbb199
Salisbury NC
Vince
Fits fine. Need 1 more flathead.
Time to turn the adapter bore.
Done.
Vbb199
Salisbury NC
Vince
The final product:
A 6 bolt full size t case adapted to a 5 bolt adapter with clocking abilities.
WINNNNNNEEERRRRR
Vbb199
Salisbury NC
Vince
And for final satisfaction..... it fits and works
Poppy 87
Bloomingdale GA
R10 Silverado
That's some damn fine work Vince. Wonder if there is a market for these adapters? May want apply for patent if so!
Vbb199
Salisbury NC
Vince
Hey thanks!
Im a little confused on things. I understood a 88-94 1/2 ton full size gmt400 transfer case would bolt right to an s10's 4l60e.. because a squarebody np208 will. (I proved that earlier in the thread)
Im gonna have to assume this must be a transfer case thats newer than 1994.
Vbb199
Salisbury NC
Vince
Next step is making linkage work....
Easy peasy. Switch squarebody linkage from passenger side to drivers side.
Vbb199
Salisbury NC
Vince
Seems legit-ish
Vbb199
Salisbury NC
Vince
Did some quick measuring.
I needed 16" from trans centerline to front axle pinion. I got about 20" now with this double cardon driveshaft. That should be more than enough, and kf necessary ill grind the ears off the yoke to let it travel further. i can have 4x4 now!
Slick work!
Hey thanks!
A transfer case from a full size truck does bolt right up to your trans, but you have to use the adapter from the full size truck too. The small trucks used a 5 bolt adapter for the smaller t-cases with a 5 bolt pattern.
But that doesn't concern you, lol. You have the ability to make non-matching parts fit together and it looks like it will work perfectly.
Vbb199
Salisbury NC
Vince
Slick work!
Well ****...
And YOU KNOW WHAT!?!
that full size, 6 bolt adapter i have.... somewhere...
Gets me to thinking... maybe ill go to a ford np205 at some point if i step up my engine and trans
twitch1989
