1992 Camaro RS
So I've got a mild misfire to chase. I pulled the right side valve cover again and the valves/adjustment seemed ok. No bent pushrods. I suspect I just need to replace the plug wires.
Now that the fuel system seems to be sorted out, I can buy a good quality fuel pump and get it installed along with the replacement tank. With only maybe an hour of run time, that cheap pump is already losing pressure. It's getting down near 10 psi already.
Here's my temporary fuel system, lol
Is that a wire nut? You stooping to my level of engineering? :p
Moderator
I'm not sure what you are seeing, but no lol. There's not a single wire nut to be found anywhere.
However, I did run some flush-head self-tappers into the water damaged left door panel though :rofl:
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
Although the fox body mustangs were far more typical. I remember New York State police use to buy a couple V8 camaros in that regular chevy metallic blue for smooth roof highway super pursuit/ interceptors and put the gold stripe on them,..
(in 1992 it would have been almost all, crown vics and caprices though,...dodge had given up on RWD, so no Diplomats in the bid mix anymore).
edit: found a image of a 1992, with a big old light bar to bite the wind like a barn door.
jw23655
