JT58
- Aug 1, 2023
- Naples, FL
- JT
- V10
I did not want to post another TBI thread but I need help. I have read just about every TBI post on line. I have a beautiful 1987 V10 short bed stock, 350 engine, SM 465 manual. (Engine is a 1974 transplant) with original 1987 electronics. It runs great, powerful and steady at all RPM except it does not idle steady- when warmed up. It hunts up and down. It's fast idle at start up is perfect and steady. I've tried just about everything for 3 years now- new EGR, TPS, IAC, MAP Sensor, Plugs, Wires. Also new charcoal canister, two new fuel pumps in the tanks, all new vacuum lines. I used top notch parts too- AC Delco when available. I tried resetting the idle but it appears and that OBD2 port is inoperable or dead. Truck has no lights- check engine, etc. When I jump the ports and disconnect the IAC the idle screams high. I have checked for vacuum leaks- none. The truck had a bad thermostat, stuck at 160- I put in a 180 Degree, did not help. The TBI electronics supposedly need 195 degree although this may be too hot for the 1974 engine.
Suggestions to fix it? Could the fuel pump pressure be too low- inadequate fuel pumps in the tanks? Maybe the thermostat needs to be 195 degree? How to fix inoperable ODB2? Is it worth the aggravation?
Or should I just go carburetor since I do have a 1974 engine? I'd have to change the intake manifold (The engine already has the 1974 heads with side bolts, not the center bolts- someone before me changed to 87 TBI manifold), change to HEI distributor, 4 barrel carburetor and install a fuel pump regulator. I am going to have a local shop assess it in a couple of weeks although they charge $$$$$ and may not be able to even do anything since it is a mix of 1987 and 1974.
The rest of the truck is so great, mostly all of my own work to restore it so far. It drives, tracks and runs like a new truck except it won't idle. I want to do what is best and most economical. Thanks for any help.
