1985 k30 starter
amyaleppo
maine
Amy
k30
Any tips on how to get this past the flywheel/, driveshaft, or exhaust? Its unbolted but stuck between this stuff.Am I missing something here or do i have to remove something else. Thanks.
Craig 85
Nashville, TN
454/TH-400/NP205
Mine come right our with a little twisting of the starter. I have a big block though and a 3" lift.
amyaleppo
maine
Amy
k30
You pulled from above or below? I also have a big block and a lift.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Pictures would help?
amyaleppo
maine
Amy
k30
Must be because someone put aftermarket headers on - i guess i need to take out drive shaft : (
Craig 85
Nashville, TN
454/TH-400/NP205
I removed mine from the bottom. I don’t recall any issues getting it in and out. The biggest pain was getting the shims back in when re-installing it.
I just read your last post as I was posting. I have factory manifolds.
Bronze Knight
USA VA
Robert
My truck is quite similar. 1985 K30 with a 454 big block with headers, stock height and stock tires. However I can get my starter in and out no problem. Got any pictures?
amyaleppo
maine
Amy
k30
I dropped the drive shaft - problem solved- but thx all!
  • Like
Reactions: WFO
Moderator
Usually it's the opposite... sometimes you have to pull the starter to get the header in.
At any rate, that's an odd one for me. I've had small block, big block and many different brands/models of headers on these trucks. The starters have always fit out in the opening provided.
amyaleppo
maine
Amy
k30
It was def some aftermarket stuff so who knows. But thx for responding.
Jeremy89
