1980 K10 4x4 with 350 Rear End Need Gear ratio
mejiar1969
Adkins tx
Chevrolet
I’m fixing up a a this truck. The rear end needs to be replaced. There’s no tag in the rear end. Any idea what the gear ratio is hot this truck?
77 K20
Montana
K20 5" lift
HT383 fuel injected
FYI- C10 would be a 2wd
K10 would be a 4wd
Is there any sort of sticker in your glove box? If it is there then it will either say or have a code for it.
3.73s were popular.
Otherwise you can jack up the rear end, put it in neutral and observe the ratio of the driveshaft turning compared to the tires.
Welcome!
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Rickf
Grafton NH
1974, 1954 & a 1937
Pull the cover and count the teeth.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I will guess 3.42's as that is what is in Goldie , my 80 K1500 Suburban .
That's assuming the same TH350C auto tranny like mine, though .
Good Luck!
Britt
78C10BigTen
pennsylvannia
C10 BIG TEN
Easiest way to do it is jack it up, pull the cover, rotate wheels till the numbers on the ring gear come to you then find the digits and divide them.
Arlo
Tomball
Arlo
Still Debating
3.07 Gear
roundhouse
atlanta ga
justin
77,78,79,80 ?
Could be any thing
I’ve seen 3.07
3.73
4.11
4.56
Only way to know is pull the cover and count the teeth or find the number stamp
You need to change the oil and inspect the diff anyway
Craig 85
Nashville, TN
454/TH-400/NP205
My California smog '79 K15 had 3.07's.
rpcraft
Robert
LS 6.0 364 CID
3.07 was probably one of the more popular gear ratio's put in the 4wd trucks that came with a TH350. They did put some higher numbers of 3.73's in the 700r4 trucks but 3.07's were still more popular by a wide margin. If you are doing maintenance you should plan on changing the rear diff fluid, so you might as well get you some replacement gear oil and a gasket for each diff, plus some RTV, and have at it. While in there you can spin the diff around, check out the numbers, do the math, and also determine if you have an open diff or whatever going on in there. There's really no way to tell without actually seeing the gears at this point. EVen if you had the RPO code's and other info a previous owner could have changed the gears out.
johnalen76
