10 bolt rear end
87ChevyR10
Kansas
NA
NA
NA
So, I took my truck to a shop to have u joints replaced and a leak in differential fixed. I get a call the next with the saying the differential has 27 degrees of play! Today, they call with an estimate, and it'll run me about 1500 for them to rebuild it. Holy crap, I was not expecting that! Shop is looking for a good used unit now. Hopefully that'll cost a lot less!
What should I expect to pay for a used rear end?
Georgeb
Wisconsin
George
K10 Burb Z71
First thing I would do is verify that it is ring and pinion lash and not just slop in the side and spider gears...... Slop in the side and spiders means you have a lot of time left to look for an axle and save up some cash. It's worth your time to look into it further.
87ChevyR10
Kansas
NA
NA
NA
Thanks, man! How am I to know the difference?
yevgenievich
Viktor
sad
very sad
less sad
As for price, $100-$200 is a going range for my area. Currently, personally have one for sale for $200 obo.
87ChevyR10
Kansas
NA
NA
NA
Thanks! That's encouraging! If that's all it is, I'll go ahead and have them replace it.
Georgeb
Wisconsin
George
K10 Burb Z71
The cover needs to be off to check it but basicaly you turn the pinion and see how far it turns before the ring gear moves. Then see how much play is in the side and spider gears. This little video shows the play I am referring to.
https://m.youtube.com/watch?v=0boH6WIs7Yw
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
5-11 degrees is typical tolerance range of a new r&p setup, 14 degrees max for a used setup. 27 degrees may not have knifed the gears too bad depending how long it has been ran like that but hard to tell without looking at it. It would be nice to just shim the carrier a little closer to the pinion and check the mesh pattern. If that would do it, it would just be a couple hours labor and no parts expense since you would just be rearranging shims that are already on either side of the carrier. If the pinion would have to be reset to make the pattern right the expense would just be a shim or two and a crush sleeve and another hour or two labor. If the gears are severely knifed and debris in the oil they would want to replace bearings and all. That would be around $400 in parts and at least 4 hours labor, at I'm guessing $150/hour being a fair rate in my area at least. If this isn't your daily driver and you have some mechanical know-how you could do it, but there are some specialty tools required. A high-torque impact wrench, dial indicator, micrometer, bearing press, and inch/pound and foot/pound torque wrenches.
Georgeb
Wisconsin
George
K10 Burb Z71
I have to ask:
Has the cover been removed for a visual inspection?
Is there debris in the bottom of the housing?
Has there been a visual inspection for knifed gears and lash in the differential gears?
There may not be a real issue here at all. More info is needed to make a call on it.
87ChevyR10
Kansas
NA
NA
NA
The only thing shop has said about rear end is that it's not making any noise. I'm going over there this afternoon to have a look at it myself.
87ChevyR10
Kansas
NA
NA
NA
So, just got off the phone with shop. They said differential needs new spider gears. So, total cost for u joints, pinion seal, and tack weld ball joint socket will be about 700. So, I'm going with it. Hopefully I'll get the truck back next week.
Georgeb
Wisconsin
George
K10 Burb Z71
And there you go!
87ChevyR10
Kansas
NA
NA
NA
Got the truck back today! Man, does it run smooth now! Truck used to vibrate so bad, all 3 mirrors shook. Glad it's back!
MikeB
North Texas
$700 seems reasonable. I'd guess 4-6 hours labor if the shop has a lift and a guy who's familiar with GM rear axles. Heck I'd rather replace spider gears than u-joints!
Make sure they replace the axle seals while they're in their. And I'd probably spring for axle bearings. Probably no more than an additional $30 parts and 30 minutes labor.
Whoops, just noticed you got the truck back. Glad everything worked out!
iamberttt
