I will snap a pic when I get home. I had some general questions about the glass they said they needed a few days to get for my appointment. I knew this would get interesting... speaking to the Safelite rep(not a technician) she told me it would be a full 4 panel slider window. So it will be an entire back glass replacement. I then asked if it will be tinted or clear and she says: "I don't think we can get tinted glass for this vehicle" I says "ok". Then she goes:"if we can even get the replacement for your vehicle" I left it at that knowing I have an appointment on the books. I am expecting a call-back from Safelite in the time between now and the appointment date. :rolleyes:
That looks exactly like the C.R.Lawrence back glass I got out of a junkyard for my truck. All aftermarket sliders use the factory non-slider gasket. As far as I know, there are no companies making a clear rear slider replacement for our trucks. Looks like Brothers bought them out at some point and Holley still sells them for ~$285
https://www.holley.com/products/ext...yi_9ssM0dWnU0lBxYrZU-LmjC0KJd5SBoCmrQQAvD_BwE
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I agree about the focal point looking near the latch. Is your latch super difficult to latch? I would imagine Safelite is going to do a full replacement rear slider, it's pretty hard to find pieces for these. Shoot a pic of your gasket/glass near the corner. I'm curious if yours uses the OE seal or not. It kinda looks like it does
To answer your 2nd question: No the latch was not hard to close or open. Up close pics of glass/gaskets/latch. The sun is shining in through all the shards and it it super bright where I am taking the pics, sorry about the light. Broken side glass/gasket:
Latch and non-broken side:
I also wanted to open the latch but am avoiding making the glass fall out. It's gonna be 6 days before the said replacement is installed. What do you think I should I do to protect the window/cab? Tape? Tarp cover?
Personally what I'd do and have done cut a backing out of cardboard,then cut another backing out of cardboard for ridgity,have an accomplice hold the backing against the inside. Use clear box tape in strips each strip overlapping the previous strip by 1/2 overlap bottom to top like shingles.Water will run off like shingles on a roof and you can actually do it neatly and not look as ghetto as a something taped over the window.. tape the inside second to keep pieces of glass from falling in. It is a delicate process.
If it were me, I'd just use clear packing tape and go over the whole thing carefully inside and out. Don't open or try move either side, just tape over and wait for it to be replaced
RaisedK5
Leland
Blazer
The bit#h is it's tempered,so unless you find a replacement piece from the manufacturer a glass company cannot cut you a piece. Push comes to shove I'd cut a piece of lexan.
It's not that difficult to get tempered. You are correct that you cannot cut tempered glass but you can have glass cut and polished and then tempered. I used to order tempered glass pieces regularly when I owned my hardware store.
Thanks,maybe its more affordable elsewhere. I needed a piece of tempered glass about 8x18 inches. Went to the local glass shop ( small town ) they said you can't cut tempered glass that have to cut it send it to be tempered and cost me like 175.00 that was maybe 15 years ago,who knows what theyd charge now.
WFarm
Central Virginia
K5 Blazer
I restored these wonderful antique Dayton scales and would order tempered glass ovals and rounds for them from this company. A big, thick one as shown was around $75 I believe but it was thick and had rounded edges so a plain flat rectangle would be cheaper. Plus you can size it all out and get a quote on their website.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
As long as you don't slap it on like the ad guy does
I used Flex tape. I got one roll thinking 4 inches wide by 5 feet is plenty for one slide glass pain. Nope. Carefully covered it outside while my daughter held card board up on the inside, then I ran out halfway across the inside. Packing tape for the rest.
:confused:
RaisedK5
Leland
Blazer
Wow. That's some ********. Although my reference is big city. LA County with the supplier in Long Beach. Probably would have cost me $40 in 1/4 for that size.
Strick
Dunn, NC
Harold
C20 Crew
Still working on the 78 K25. It’s a runner but the site will not upload a video unfortunately. We got a full exhaust ran from the headers back & we just finished the twin stick conversion on the NP205. Maybe we’ll have the front clip back on next week.
ChuckN
Bellinham, WA
Chad
Got the vacuum gauge installed, and just got back from the cruise and tune. I think it wants the next size up metering rod, that will be interesting.I was able to dial in the step up springs (definitely needs the most aggressive silver spring) and also the idle mixture.
92gtseater
