82SquareBurb
- May 1, 2025
- Soddy Daisy TN
- Derek
- C10
Hello,
I am doing a R134a conversion/retrofit on an 82 Suburban. I am replacing the compressor with a Sanden 7176, (relocating to the passenger side with a new drive setup) all new hoses, O-rings, new parallel flow condenser, accumulator/dryer, and orifice tube. Since I am relocating the compressor and need new lines anyway, I am having trouble finding a source for the special "Tee" fittings that feed back to the rear AC. I attached a photo showing them. I looked on coldhose.com, and saw no option to add in any kind of splitter or junction. I have yet to find any fittings that will work. I may just need to ditch the rear AC if I can't find the lines/fittings. Has anyone been successful restoring the rear AC?
Thanks
Thanks
