1990 TBI misfire/popping exhaust
cbrown5385
Mass
Corey
Suburban 1500
My 1990 TBI just started having a bit of an issue. It idles and Revs in the driveway fine but but some times while driving I’m getting almost a misfire/ popping from the exhaust. I’ve started it up and unplugged vacuum from the EGR and I had no change in idle no rough idle not stalling not. No change at all really. Can anyone point where I should be looking or what’s I should be looking into
gmbellew
Kansas city
glen
suburban 1500
EGR is closed at idle. so unplugging the vac to EGR doesn't do anything at idle. manually opening the EGR, or using a mityvac to open the EGR, should cause it to bog at idle.
I'd hit up the fuel and emissions manual and look at the "symptom" charts for backfire and misfire. I think section 2 has the symptoms charts, separate charts for backfire and misfire
you haven't recently changed the plug wires?
cbrown5385
Mass
Corey
Suburban 1500
I did new plugs and wires when I put headers on it the end of last year then it sat all winter ran good first few days once out for spring then started the issue. I did NOT do a new cap or rotor at that time though
Wait until after dark spray the cap and wires all the way to the head,with salt water out of a spray bottle. Look for lightning.
gmbellew
Kansas city
glen
suburban 1500
might double check to make sure you have the firing order correct.
fast 99
Spokane, Washington
Those distributor caps can crossfire internally. Sometimes it's not visible.
We only use Delphi. More expensive by a lot. This is not a place to buy an economy part.
gmbellew
Kansas city
glen
suburban 1500
We only use Delphi. More expensive by a lot. This is not a place to buy a bargain part.
yeah, inspecting the cap excess carbon is a good idea. and I agree on not skimping on ignition components!
Danger Dave
