ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
The Eddy carb has limited ports.
The trans modulator is connected to a fitting on the manifold itself, the rear (large fitting) is used by the brake booster, and the front is used for full manifold vacuum for the timing advance (not ported vacuum, the full vacuum fitting). If I tee into the vacuum advance line for the gauge, will that throw the signal off to the advance? The purpose of this is for carb tuning (metering rods and step up springs) and if it affects the timing that would ruin any accuracy. Post your suggestions, thanks in advance.
Chad
Chad
