Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
Number one son bought a 94 blazer for cheap. It’s been seriously abused and beat, but has some neat parts/options that will eventually find its way onto his Yukon.
I’m not very fluent in sbc stuff. Are any of the later model pass side dipstick blocks desirable? Are any 4 bolt mains? If I remember correctly, the pass side dipstick also means one piece rear main seal? What/where are the casting numbers?
While the engine does turn over, the previous owner started tearing it apart for some reason. The oil appears clean, unfortunately the oil filter is gone or I’d cut it apart for inspection.
What’s a sbc core worth? I’m guessing with the popularity of the LS swap the old stuff isn’t nearly as desirable as it once was.
If it’s worth 200-200 bucks, I might pull it. If not, it’s going to that big scrapyard in the sky with the rest of the truck.
