- Feb 28, 2017
- Central IL
- Quincy
- K30
So I was doing some looking around under the truck because I had bought new bushings for the leaf spring shackles and eyelets and was eyeing up the disassembly.. Needless to say, after much closer inspection I figured out why the rear axle sits a little crooked under the truck because what I thought was causing it was the bushings being shot and letting the spring shackle sag and twist but I discovered that the left hand rear leaf spring hanger is twisted about 3/4" to 1" out of square and it is basically shoving the axle forward on the left side. I don't know where, when or how as its been that way since I bought it, but now I want to fix it. Looked around and it doesn't appear the truck has been hit as the only thing I can see is the hanger is bent so i'm assuming at some point in its life it was waaaaay overloaded. But a quick online search of a few places didn't come up with any good results for in stock parts. Anyone here ever come across a site to source these kinds of parts? Or have good luck with a pick and pull? I have a friend who's body shop has a frame machine but I just don't know if bending that hanger back is the right way to go? I feel a replacement would be the better option. But the usual LMC truck and rockauto and a couple big box parts stores didn't have much luck in a quick search. I am going to do some more looking today to see what I can come up with. But curious if anyone has found a good replacement online. And if so, how was the fit and finish. I would like to go back with a stock style hanger, and no I will not do a shackle flip with aftermarket brackets. Call me old fashioned or just let me have my feelings that it is a dumb idea for 90% of what these trucks do and are built for. Just not a fan. I feel the same about shackle flips as I do about "bro tires" on these trucks. Will post some pics later tonight as I forgot to take any when I was under the truck and I know how much everyone loves pictures. Thoughts on repair vs replacement?
Edit: forgot to mention I did find some in stock C/K 3/4 ton brackets but aren't sure if they are the same for a K30, can anyone confirm?
