- Jan 23, 2013
- Georgia
- Roger
- Jimmy Sierra
Welding cable has more, thinner strands to make it more flexible. Unfortunately the jacket is not as oil resistant as battery cable. Marine cable is similar to regular battery cable in that it has more oil resistant insulation. In addition, the strands are all tinned to help with corrosion resistance. It's also a more expensive.
DC circuit capacity is determined by the total length of the circuit, so from the battery to the load and back to the battery. Then acceptable voltage drop. 3% or 10%. So let's say you need 20ft of 2ga cable to get to the plug at the bumper and another 20 ft to get back to the battery. Allowing a 3% drop in a 40 ft circuit you can carry 30 Amps. If 10% voltage drop is acceptable you can carry over 100 Amps.
There are formulas for this, but it's easier to use a table like this:
https://www.westmarine.com/WestAdvisor/Marine-Wire-Size-And-Ampacity
Circuit protection is a must as stated earlier. You can probably get by with a fuse if you go with such heavy wire since you'll have excess capacity, but circuit breakers are available too. Just more $$$. Also as stated earlier, proper terminals, properly crimped and sealed with adhesive-lined heat shrink will go a long way to keeping everything working as intended.
X2!
