2015 Camaro V6 2LS
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Interior, license plate and reverse lights all switched out last night. It really does make a big difference.
For $5 A light. Now we'll see how long they last.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Picked it up yesterday after getting rear ended one month ago. Did a great job. 6k worth of repairs. So glad to get back in it.
New rear bumper, tail lights, bowtie and brake light on trunk. He bent the exhaust on right side when he hit me. So they put a whole new exhaust system on it since it's one piece.
It really wasn't that bad but, still racked up 6k real quick. 1,200 was just in exhaust. It took a bit longer than i thought it would but, that's because of the strike.
Glad to put that behind me now.
82sbshortbed
Fuckemall!!
SE Texas
Doug
I was getting groceries out of the trunk and noticed the big scratch on the trunk is gone. Then I noticed the 2 spots on the top of rear fender where the clear coat was a messed up a little were fixed too. The wreck didn't cause either but, both got fixed. Yay
82sbshortbed
Fuckemall!!
SE Texas
Doug
Got the amp and sub installed yesterday. The stock stereo system is good I got no complaints. I just wanted to enhance it with the sub. Gotta say I'm really glad I did because it was just what it needed to complete the system. Sounds great now!
82sbshortbed
Fuckemall!!
SE Texas
Doug
A cool partly cloudy day is a good time for a hand wash and wax. Been a couple months on the wax so perfect time for it. Black sure is a bitch to keep clean but, it sure looks good after a wax. :naughty:
Also put new conventional wipers on it. I didn't like the ones I had on there. Much better.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Well, the last couple of times I started it ir was a slow crank then start. So today at break I started to get the battery out. It's in the trunk. Gay!
I have a sub in the trunk. So had to disconnect it and pull the amp off the speaker box so I could get to the spare that sits on top the battery. Why like that?
Finished up at lunch but, found out something gay again. When you disconnect the battery you can't open the trunk or open the doors. I actually had the trunk open and the drivers door open. I went to open pass door to put the sub in the pass seat and it was locked.
Anyway $187 Everlast from Walmart after work and it's all back together but, dam that was stupid. I'd rather pop the hood and change it out. Fires right up tho. Just a pita!!
Carb'ed Vortec 350
I had both the battery and starter go bad on my jeep. Thought it was the battery, replaced it, and then a few days later the starter showed its age. I mean the battery was going on 6 years in service so it was past its prime, and the starter was going on 16 years in service. So I got my money's worth out of each unit. I hate being stranded because of stuff like that. Battery in the trunk? That is lame!
82sbshortbed
Fuckemall!!
SE Texas
Doug
After washing the square I decided to wash and wax the camaro. It needed it. Much better now. Lol
Blacks a bish to keep clean but looks great after a wax.
Midnightmoon
Pennsylvania
Justin
While you are at it, I'll bring my Sprinter van over to you. That is, since you like waxing black as much as you do....LOL
82sbshortbed
Fuckemall!!
SE Texas
Doug
Haven't posted anything here in a while. So put new front rotors and pads on it today. Took me about 3 hours. The 18mm caliper bolts were tight af! Probably 1st time they were off. Had to use a dead blow hammer to get them loose.
Old ones were grooved but not terrible. The pads were cracked. I'll do the back next weekend. I'm wore out too. Had to grind one pad a little with the dremel to get it to fit. Never goes perfect. Lol
Was able to clean the inside of the rims real good too. After I get them all on I'll paint the calipers yellow too another weekend.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Got these custom made ultra floor matts for the camaro. They're really nice and cover the entire floor. I wish I would have gotten them earlier. Definitely recommend for a brand new car.
You could leave Matt's in or out. I'm cleaning the drivers side matt it dirty af. No pictures but I got the back Matt's too.
DAT_141
