Unidentified Air Filter Intake
Dave C.
Hamburg, NY
Dave
I have an air filter assembly from a friends 86 or 7 k10 which was ditched when the carb was changed. Ive seen this style air filter housing before, but not the air intake hose which does look like a factory type setup. Can somebody please verify if it is indeed a GM piece, or just an aftermarket contraption?
Keith Seymore
Motor City
Keith Seymore
4.3L
It’s an optional air intake water or dust separator.
If you can still access the truck it should show on the SPID label.
K
Interesting
K
Well I'll be damned! Really?!
I saw the picture of the inside and instantly was reminded of the afternarket "Tornado" contraption.
Big Chip
Michigan
Kevin
C35
That
That was my immediate thought too.
chengny
YEA
K
Yeah, yeah he nailed it. It's a preliminary air separator used as part of the RPO K46 option (air cleaner, heavy duty, pre-cleaner).
It is essentially a cyclonic type air filter/separator. The bladed disc doesn't spin. It is designed to impart a centrifugal force to the incoming air flow as it passes through the blades. Any moisture/particulates that are entrained in the combustion air get flung out to the ID of the pipe and drop down into that hopper shown in the last picture. That pointy looking thing under the hopper is called...IDK...the purge valve maybe. It is rubber and has a slit at the bottom. When enough stuff falls down into the hopper, something (again IDK, maybe the weight of the junk or an increase in air flow across the blades). The slit in the boot opens and purges some of it.
The engineers really love these because the never get clogged - like a paper filter. And perhaps more importantly; due to the fact that they never get clogged up - even in harsh environments - combustion air flow is always unrestricted.
That's all I know - or can remember anyway. Oh yeah, I believe they were first used in tanks during WWII.
Dave C.
Hamburg, NY
Dave
Thanks guys. Pretty neat that the engineers were playing around with stuff like this. Unfortunately the truck has a new owner so I cannot verify the code.
Someone should put a motorized fan in it as a mini turbo!
Keith Seymore
Motor City
Keith Seymore
4.3L
I was in the chassis/Powertrain group for a little while and designed the engine air induction system for the GMT800 vehicles (1999 model year and beyond - most of the system is still in use today).
Otherwise I probably would not be familiar with that hardware.
K
Jppr26
Deer island
V20 custom deluxe
My brother in law bought one of those "As seen on tv" electric turbos for his geo metro, all it did was choke off the intake
MatrixFab
NorCal
Daniel
C/K 20
I have a 1984 454 C20 the came stock with that assembly. It is in poor condition. Is this assembly for sale? Willing to buy it if available. LMK Thanks
Wow, this means GM built at least two of them. Lol.
This must be one of the rarest options of all. I wonder what total production of those separators was?
kevbak88
