Rustabout
Arkansas
Derrick
k-10
Put on some American made Mickey Thompsons on 6 Lug rally wheels. 31x10.5x15. Did some measuring and appears truck was already given a 2 inch lift before i got it. Next is gears and lsd when budget allows.
Sad Sack
Nebraska
Goober
C15
Putting everything on hold for old people problems. At least parts are on site
Getting old sucks…but as long as you can still give the finger, there’s hope.
78C10BigTen
pennsylvannia
C10 BIG TEN
lubed up the window tracks. So much easier to crank them down.
I actually just did this today on my s10 because the pass window was STIFF! I just applied PB to all the moving parts and run the hand crank a BAZILLION times until effortless lol.
Camar068
Air Force Supporting Member
10 yrs Air Force
@78C10BigTen @Johnny Atomic I used kiwi camp dry....few sprays and it was good. but I knew there was something else to it but I couldnt find the video for the whole process. It had to do with PB blaster dry lube also. The kiwi did the trick, but I know I didn't do it right. Guessing it will show up in a few weeks and needs the dry lube.
unimogguy
Wheat Ridge, Colorado
Went from this: —————-> To this:
I’ll be looking into getting the frame bent back straight in the near future.
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
i'm wondering how brand dependent this is. How different is Kiwi or any other spray silicone waterproofing. To me it just Sounds like just a silicone spray followed by a graphite dry lube spray. Silicone spray will soak into the rubber, graphite will then sit on the surface.
CheemsK1500
K1500
I finally converted my 6 lug front to an 8 lug (Previous owner installed a 14 bolt rear). It is nice being able to carry only one spare tire and have the same size lug nuts on all four wheels.
78C10BigTen
pennsylvannia
C10 BIG TEN
My 78 is the same way lol a 6 lug rear and factory 5 lug 2wd fronts lol
jw23655
