RoryH19
- Aug 21, 2015
- Texas
- Rory
- R10 Silverado SWB
- 350 TBI
Hello.
I've been researching axle swaps for my k5. I have a 14bSF from a 4x4 gmt400. It will widen the rear axle to basically the same width as the stock front axle.
I was also thinking of converting to disk at the same time since the drums are shot.
I then thought about using the gmt800 with factory disk brakes. I found a 14bSF from an 05 Escalade with 3.73 gears which I already have.
From what I've read the 4x4 gmt400 axle is the same width as the gmt800.
Has anyone done this swap?
I'm sure the spring perches and shock tabs will need to be changed. Maybe a new prop valve too.
Pros/cons?
Anything else to consider?
Pros/cons?
