Mystery of the disappearing brake fluid...
Frogman
Durango, CO
GMC K1500
Ok friends, here is something I have never experienced. '78 Chevy. This is my elderly neighbor's plow truck. I moved it for her last fall and the brakes did not feel right. Popped the cap of the reservoir and the front chamber was empty. Bone dry. I guessed probably a bad wheel cylinder; I would deal with it in the spring. I went out last week to fill it up and bleed the brakes so I could move it to investigate. Popped the cap and now both chambers have fluid????
Thoughts?
Smtty58
Mass.
Lyle
R3500 Crewcab
Is it possible somebody went to move it after you parked it? They may have noticed the brake issue and filled it.
Sad Sack
Nebraska
Goober
C15
Prankster?
WesN
Edmonton Alberta Canada
Wes
C1500
If nobody used it and or it has not been run it could stay full.
duncan_schawalder
