Strange thing with ball joint on k20
gwhunter21
Thunder Bay On
Tom
Check this out had a ball joint come dang near out of the socket. Was seated fully and was tight fitting in the socket. Any ideas why other then the obvious it being a bad knuckle
legopnuematic
Licensed Junk Dealer
MO
Spencer
Was the upper sleeve adjusted properly during install?
The upper and lower joints are in compression in normal loading. That’s all I can really think of that would draw the upper out.
gwhunter21
Thunder Bay On
Tom
Probably not, it went for a wheel alignment and then for a safety and that’s when that was noticed.
wonone
