Hunter79764
- Sep 1, 2021
- Grand Prairie, TX
- Shawn
- Suburban V20
I'm trying to diagnose an issue on my wife's Yukon. It's a 2013 Denali with the 6.2l, I have deleted the VVT and DOD quite a while ago, and did an engine refresh with a mild cam about a year ago, transmission was rebuilt about 3 years ago by a good local shop with upgraded parts including a semi-billet converter and was running fine until a month or two ago, and it has been a crazy busy time with lots of out-of-town trips and family issues, so time to diagnose has been scant and I need some help.
On to the issue -
There is a very noticeable hesitation/misfire/stumble/cut-out? at very certain conditions, essentially 1800-2100 RPM and ~60% throttle or more. It shows up easiest when cruising 65 or so, and rolling into the throttle to speed up to 75 but without downshifting. It feels like the engine completely loses power maybe twice a second, fairly rhythmically but not like a cylinder misfire, but not like a carburetor bogging down either. Kicking into 5th, going to 2200 rpm or so, backing off, or anything else to get out of that zone makes it go away. It is not limited to 6th gear, I can force it to do it in other gears, and even power braking in 1st gets a similar action, so I think that rules out a torque converter lockup cycling (which was a thought). The entire vehicle moves with it, I would not say "violent", but it isn't something that you have to really pay attention to notice.
I have logged with HPTuners all the regular stuff and the only thing I saw was that the fuel trims that are -3 to -7 for most of the map flip to 2 to 5 in the couple of cells where this issue happens, but I'm not seeing any lean codes (or codes of any kind), misfire indications, O2's seem to be switching normally, fuel pressure dips a little bit, but not crazy (it has the variable fuel pressure, at that load it has a 43 base psi and dips to 41 or so at tip-in, but recovers quickly and I believe does the same at other load points at tip-in without causing the surging). Otherwise, I can't actually see the surge on the datalogs at all, other than maybe seeing the RPM drop or flutter.
It reminds me of an issue I had with a loose ECM ground on a swapped vehicle I had, where the computer was basically dropping out, I have checked the major grounds and saw no issues, but I do have corrosion on the negative battery cable. I need to check the minor grounds, and I'm going to replace that cable anyway, but bypassing it temporarily didn't change anything so I don't think that's my source issue.
What other things should I check? Other items to log in HPTuners? I'm going on a ground and power hunt this weekend, what else should I be looking for? New-ish alternator, good battery, dash gauge shows steady voltage although I have had a bit of headlight flicker the last year or so, if that seems like it could be related. I'm just at a loss right now.
On to the issue -
