Smog removed: how to cap manifolds?
dec322
Indiana
Scottsdale K10
1984 k10. The PO removed the cats.
I just finished my timing chain, water pump, oil pan gasket change and decided to pull the smog pump. Some of my vacuum lines are already plugged by PO. I am trying to figure out how to cap the pipe that comes off the top of the exhaust manifolds. I read an oil plug off of a dodge diesel but no specifics. See pic for reference.
Any insights?
1lejohn
texas
john
k-1500, 2500 HD
If it's regular pipe threads, use a pipe coupling and plug. Or you can remove the tubing from the manifolds and use pipe plugs on the holes in the manifolds.
Edelbrock
Earth
Grumba
K5 Blazer
Ya, I would just go to Ace Hardware, Lowes, Home Depot etc and buy every cap that they have that has about the same diameter. Then go home and try one after another until you get a winner. Then just return the rest of the caps. Keep your receipt and its a quick and easy return. Another thing that works is to clamp a short rubber hose over that pipe and then stick a large bolt in the other end and hose clamp that in place. Its looks kinda ghetto, and doesn't seem like it would work - but it does work. That pipe doesn't actually get that hot, relatively speaking.
dec322
Indiana
Scottsdale K10
I thought about removing the tubing but saw some pics of caps on these.
I have a ghetto fix with a plug in the hose but your ghetto fix would be less janky .
Ultimately, I want to do a ls swap. I use the truck to cruise so I’m not too worried about engine bay looks at the moment.
dec322
Indiana
Scottsdale K10
I ended up picking up a couple of 1/2 pipe caps from Ace Hardware. I used a JB weld high temp paste in the threads to prevent gases something through (yep…it’s permanent). Pics of finished product and products used….for future search results
Edelbrock
Earth
Grumba
K5 Blazer
Looks good man. That should hold it.
82SquareBurb
Soddy Daisy TN
Derek
FWIW: Since I just did the same thing on my 82, thought I would share what worked for me.
I went with these to plug the holes in the manifolds and they worked quite well.
FYI
JT58
Naples, FL
JT
I used a 94-01 Dodge Cummins oil drain plug I bought off of Rock Auto. Thread size is M22 X 1.5. The oil drain plugs fit perfectly.
dec322
Indiana
Scottsdale K10
FYI
Looks good. I did not want to fight with the exhaust bolts…the truck has been down long enough and I didn’t want another thing to deal with.
Did you remove all of the smog stuff….even the canister?
Removing the canister is not good advice. I also would prefer to have working egr. There is no down side to egr,cooler combustion chamber temperatures,more ignition timing,less knock prone,less throttling loss.more mpg
Edelbrock
Earth
Grumba
K5 Blazer
FYI
Nice work. Amazon is awesome for stuff like that. Cheap, fast, excellent return policy.
ghopp24
TN
Greg
Headers are much easier and more hp.........
grego28
