TH400 Slipping When Warm - Chunks in Oil Pan
82sierradude
Pacific NW
Ben
C2500
My truck's TH400 2wd transmission leaks when parked and slips after it's warm. I replaced the vacuum modulator, pan gasket, and filter less than a year ago. I found what appears to be plastic chunks in the oil pan and some fine metal debris. Governor gear is fine. Thoughts? Am I looking at a rebuild?
Thanks.
NickTransmissions
Las Vegas
Nick
Thanks.
Yank it out and overhaul it! Debris like that in the pan = rebuild 100% of the time.
check out my TH400 Information Thread for video tutorials, parts lists, tips/pointers and additional resources to help you with the overhaul.
82sierradude
Pacific NW
Ben
C2500
Thanks. Any idea which part may have shredded into pieces and ended up in the pan?
NickTransmissions
Las Vegas
Nick
You're welcome. Looks like a combination of bronze thrust washer which sits on the front side of the rear planet and front/rear planetary teeth but hard to tell from the pictures...Let us know what happened when you open it up...Also, gear train failure (if that is what it turns out to be) in an otherwise stock to mild-use vehicle points to a restriction somewhere in your system...Once you have the trans out, extensively flush your cooler lines, internal transmission cooler and external cooler to ensure all that debris is removed...If you cannot get the cooler(s) clear after numerous attempts, either have the radiator/cooler rebuilt or replace the radiator.
82sierradude
Pacific NW
Ben
C2500
I finally got around to disassembling the TH400 because the truck stopped shifting out of first gear and has been sitting for months. The valve body's plastic accumulator piston is shredded to pieces. Hopefully, the internals are in good shape and the rebuild will go smoothly.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Hopefully you have read Nicks th400 thread.
Throw away the spring, replace the broken plastic piston with the older aluminum. Be sure to match up the piston with the intermediate band piston, there were design changes and potential compatibility issues.
82sierradude
Pacific NW
Ben
C2500
Thanks. I'll take a look.
I wouldn't throw away the spring. You never know how that could be repurposed in the future.
82sierradude
Pacific NW
Ben
C2500
I reinstalled the spring with a new aluminum accumulator. The rebuilt transmission with all new bushings, clutches, etc. is ready to go back in the car. Rear end play is 0.0012", and the front end play is 0.0011". Hopefully, it will operate smoothly.
I thought it would be prudent to replace the rear main seal - can of worms opened; I'm now replacing main bearings. For anyone who needs the info, here are the bearing clearance specs for the Chevy 305 and 350 as listed in the Chilton's manual:
#1 (Front): 0.0008 - 0.0020"
#2 - 4 (Intermediate): 0.0011 - 0.0023"
#5 (Rear): 0.0017 - 0.0033"
82sierradude
Pacific NW
Ben
C2500
Few more pics.
xm20k
Girard, Ohio
I'd replace any plastic thrust washers in there with brass while I was in it.
sbdenali
