Worth purchasing 1976 c10 silverado in fair condition for $2500?
4tunate1
california
travis
This is a Silverado 1976 c10 short bed in fair, non-running condition. Parked 6 years ago after putting in rebuilt engine and turbo 400 trans. Original 454 chassis but now a 350. Body is okay, minimal rust but it likely
Confused
Angier NC
George
76 shortbed ? Of course it is. Original 454 means it should have a 12 bolt rear. Added bonus.
Finkaire
Finkaire
California
Loren
Silverado c10
Radiohead is right, I am in California as well, if it won’t smog you are screwed. Also unless it had a non-op you will be paying back registration.
Can you see the RPO sticker inside the glove box? Having a 454 and TH400 as original in a short bed half ton sounds like a really unusual combination. Maybe they had a sport truck version, but most short beds were light duty run-around vehicles with an SBC.
Moderator
Can't say about that side of the country, but in the land of rust, that's a killer deal.
Big block shortbed trucks were not rare, but definitely uncommon compared to total production.
All '76 half tons got a 12 bolt rear, regardless of engine.
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Go for it, depending where, you are in California. I have oem parts for 350. And a complete motor with all the brackets. The only thing I don't have is the vapor canister, smog wise. Mine is a 73 smog not required and I installed a 5.3 LM7.
Like others said $2500 is a steal if it is in good shape. You can get it running.
And Welcome to the site, Norcal Redding area.
The Right side of Washington
Conditionally sounds like a good buy, but “fair” condition is subjective.
electoqute
Fort worth, tx
Terry
C30 crewcab dually
6.0 ls
California went by 25 years and older when I lived there. Had a 71 i fought for years with. Needed a timing retard cable to pass. Couldn't find a cable for it let alone the distributor and trans to work with it. Every year I had to go to the ref. And show the paperwork the parts didn't exist anymore. The day it turned 25 all the other smog crap came off. Gained 6 mpg also. Live in Texas now. No computer or over 25 yrs. = no smog. Freedom at last.
NikiFm
