Juggernaut
- Apr 11, 2021
- Illinois
- Greg
- K20
You got the turn signal switch figured out. Great job with the pictures. The brake light switch that is zip tied to that bracket is where the cruise control vacuum release should go. I would recommend you remove that switch and put it back in the original hole on the other side. I couldn't tell from your pictures what's in that hole. Maybe the original switch broken off?
