windshield wiper motor heating up??
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I can use my windshield wipers for 5 min or less and then they move slower and slower till they stop like the motor is heating up. I can turn them off for
1 min and it repeats its self. I look at my amp gauge and its close to the red sometimes. Pulling lots of amp?
Any Ideas?? thanks
Georgeb
Wisconsin
George
K10 Burb Z71
probably shot. I am surprised it hasn't blown the fuse. You could check the connections but a hew wiper motor is probably needed.
Yep, if the meter shows an increase of more than 5 amps - with the wipers on high and the blades sweeping across dry glass - the circuit is pulling too much. The problem is determining whether it is an electrical issue or a mechanical one. Here is the basic diagnostic:
If the jump in amp load is higher than about 5, pull your arms/blades off the glass. Run the wipers on high and again note the increase in load.
If it is minimal - below 5 amps - replace the blades. No improvement, disconnect the wiper linkage from the motor's crank arm and run them again.
Noticeable improvement means binding somewhere in the linkage. Locate and repair.
No improvement indicates an electrical problem within the wiper motor. Check the armature for excessive end play and shorting/grounding of the windings. Repair or replace the motor assembly as necessary.
Georgeb
Wisconsin
George
K10 Burb Z71
Very nice diagnostic advice!
While I would like to take credit for that diagnostic - I can't.
It is straight from the GM service manual (and somewhat paraphrased):
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
My wipers basically acted the same as the op. I tbought at first it was the wiper control module (located under the dash close to the steering column). Turns out after replacing the module, it wasn't the issue at all. Module was returned, and I ended up buying a new wiper motor from Autozone. Total price was $45 after giving them the old worn out motor for the $10 core fee refund. Wipers work great now.
Seems to me that the most common symptom of a failing pulse wiper module is that the wipers go renegade. They will occasionally start up and make a couple of sweeps of their own accord. It can happen without even touching the switch (as long as the key is in either RUN or ACC). If the ignition switch is in either of those positions, the hot lead to the wiper is energized. At that point, all it takes is an inadvertent stray ground path in the negative side of one of the winding leads - and they are off to the races.
I have a bad habit of setting tools and parts on the windshield while working under the hood. Naturally, these things are resting on the wiper arms/blades. More than a couple of times - with me all alone in the garage in the middle of the night - the dead silence is shattered by the sound of handfuls of parts and tools getting swept off the windshield and smashing to the concrete floor.
It isn't enough to make you crap yourself, but you do quickly stand up and take notice. Plus some things don't survive the fall. Those wiper arms are strong and can toss aside an alternator like a catapult.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Thanks everyone. Im going to replace motor first. :cheers:
kains77
