Wich oil pump to use?
Ypsik10
Ypsilanti mi
Chad
Any preferred brands?? Should I go with a high volume or what just came stock?its a 74 350 2 bolt
74 Shortbed
Stock Melling is all you need, check rotor to cover clearance .0025, high volume pump does nothing but put a strain on the distributor gear on a stock motor.
MikeB
North Texas
Probably a Melling M55.
74 Shortbed
You're welcome.:cheers:
1985Reese
