Where should the exhaust tailpipe exit....
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
to install the OEM under car spare tire?
73c20jim
Sierra Vista, AZ
Thanks Pal.
Craig 85
Nashville, TN
454/TH-400/NP205
Here's the OEM system on my K30 when I got it. Sorry no spare, one of the PO's removed it when the aftermarket receiver was installed. The tailpipes may have a little different placement due to 30 Series trucks having their shocks reversed.
RoryH19
Rory
R10 Silverado SWB
For the trucks usually on the left side, behind the tire.
Basically a 90* bend to the left. My 350 had 2 pipes side by side.
RoryH19
Rory
R10 Silverado SWB
I still have my spare tire under the bed but my exhaust now goes straight back on each side of the tire. Do you want to see the position of the tire?
77 K20
Montana
K20 5" lift
HT383 fuel injected
Here is a pic of my dad's truck. Has the stock spare under the bed. Has dual exhaust which exits both sides behind the tire.
73c20jim
Sierra Vista, AZ
please
RoryH19
Rory
R10 Silverado SWB
Sure, I'll take a pic in the AM, too dark now.
I found these online and is pretty much the same.
73c20jim
Sierra Vista, AZ
Looks like the exhaust exits ahead of the rear tires.
RoryH19
Rory
R10 Silverado SWB
Just took this but really dark.
RoryH19
Rory
R10 Silverado SWB
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Are you looking for oem routing and mounting points or are you just looking to see options of how exhaust can exit with the spare mounted under the bed?
73c20jim
Sierra Vista, AZ
Either will do.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Mine go over the axle and start aiming for the corner of the truck when they're passing the spare.
Whats left of original mount in the first pic.
3" unknown tubing.
Carterized
