Where is the ALT idiot light on 1988 burb?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
My alternator isn’t charging and I only see 12V on the pink wire at the alternator with key on, but nothing on the brown wire.
I thought the brown was the exciter, but could be mistaken. Either way, no idiot light on in the dash. Which position is the ALT idiot light in? Is there an idiot light on 1988 burbs?
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
My 84c20 with the idiot gauges came with one so i imagine yours did as well. It's also a low optioned rig so i assume it was standard
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Do you know where abouts the light was located in the dash? i.e. next to the seatbelt light, or lower left under the battery gauge?
gmbellew
Kansas city
glen
suburban 1500
My 90 has it lower left under the voltmeter
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Is the pink wire the exciter wire?
If so, I have 12 V there with ignition on. Also, if so… Is the other wire for the battery gauge?
Jgonick
West Texas
Joel
Usually-
-Brown wire is exciter (Brn 25) if you do not have an idiot light, the brown 25 wire turns into brn/white 130 and connects to the ignition switch at ign3 spot. (Side note- the brn/white 130 wire has a 10+ohm resistance - so no need for light to add resistance)
If you do have an idiot light the Brn25 wire runs to the cluster connection (to light that is fed by brn 50 wire)
Edited to correct a mistake for future reading- idiot light is generally fed by brn50 not pnk/blk 39
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Usually-
If you do have an idiot light the Brn25 wire runs to the cluster connection (to light that is fed by pink39 wire)
What is the pink/blk stripe wire with 12v key on at the alternator SFLP harness?
Jgonick
West Texas
Joel
The pink/blk wire confuses me- you usually do not see it at alternator on 1988 r/v. Note- In 1987 square bodies changed from c/k to r/v
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
What colors would you typically see and in which location (location referring to S F L P)?
Moderator
Usually-
Can you show a factory schematic that shows a restistance wire? I have never found one.
Jgonick
West Texas
Joel
Just some of my notes on alternators.
Resistance brn/wht 130 wire: A lot of the diagrams show it- it is just sort of hidden-
Several Attachments: examples 83 & 86 Wiring diagrams showing resistance wire. Also a general diagram. Also in Service Manual, & 84 wiring showing it at ignition switch. it is pretty hard to find it in all the wiring diagrams consistently.
Jgonick
West Texas
Joel
attachments: Alternator terminals for CS, recommendations for CS.
If you are using an CS alternator use the I terminal for exciter (it takes either- has built in resistance)
Several sources say to use roughly 50 ohms resistance (resistor) if connecting to L terminal (or use a bulb) especially for the CS alternator.
My research says 10 ohms for SI alternator (see service manual attachment in above post)
Here is a LINK to the Alternator Bible- I found it very informative.
Jgonick
West Texas
Joel
Generally on a CS alt. "L" or "I" is used as exciter (BRN 25 wire) And "S" (sensing) is usually red.
I’m curious - Check your alternator and see if the terminals are labeled like the connector.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Will do. It’s an aftermarket alternator, but I should still have the original around as well.
jw23655
