Where is fuel pump fuse for TBI 5.7?
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
I am trying to do a compression test, but don't want the fuel pump running while I'm doing it! I've tried pulling the connector at the relay on the firewall as well as a 5 amp fuse that is mounted to the side of the A/C box, but the fuel pump still runs when I turn the key. Is there an actual fuse somewhere for the pump? Or is there another way to get it to not run so I can do a comp test? I've got all the plugs out right now waiting to do it. Thanks!
chengny
It probably is powered by the ECM. Try pulling the ECM B fuse.
Daveo91Burb
Vancouver, WA
Dave
Cool. Didn't think of that, but it makes sense since the ECM tells the pump when to pump so it might as well get its power from it, too. Didn't get a chance to try it tonight -- will tomorrow. Thanks!
You can kill the fuel pump relay on the firewall near the AC box. Simply unplug it.
@89Suburban prolly has a pic of it he can post. I'm on a different computer and don't have my pic file.
Daveo91Burb
Vancouver, WA
Dave
Relay was the first thing I tried and fuel pump still operates when I turned the key. I also tried pulling both ECM fuses at fuse block and still no luck. I saw a pic online of a '93 with 5.7 TBI and it had the relay as well as a fuse near it on the firewall. Any other idears??
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
unhook your oil pressure switch it feeds the fuel pump
also unhook the fuel pump relay
chengny
Pull your ECM fuse and wait a bit.
If your truck is over 8500 lbs GVW, it has an override module that is intended to help with hot start/vapor lock conditions. It will power the fuel pump independently of the ECM and keep it running for 20 seconds after the key is turned on:
Daveo91Burb
Vancouver, WA
Dave
Thanks for the great info, guys. The secondary system makes sense. I should be able to get this figured out now!
imyourhuckberry
