What's the best gen 454 block to build?
75Monza
Colville, Washington
K30, K20, K20
Now that my big block thirst has hit me again, thought I would get some input since Iv'e never built a rat before. Looking to land in the mid 500 hp range with this, basically what is the best 4 bolt short block with good aftermarket stuff available. Would probably go with a good set of iron heads, don't plan on giving it spray either. Also, any ideas on staying a 454 vs bumping to 468 vs 496 and is one piece rear main better or just easier on leaks? Keeping it realistic at under $4k total build.
4WDKC
Southern Florida
Kacy
If you are planning to use a roller cam it makes sense with me to start with one so the Mark/gen VI it is for me. Depending on your plans you may even be able to use the stock efi intake, if not that and the heads can be sold, I see them listed here $500 for the intake and $250 for the heads.
75Monza
K30, K20, K20
Interesting, I know where I can get one of those, complete running 5 yard dump truck for $1k. Never really thought about a tall deck since it's rare you see them around here.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Nice meaty cylinder walls and the pan rail is nice for building a stroker. Most have forged cranks too to recoup some cash when sold. Not all were 4 bolt main blocks but a lot of them were. I have one tucked away. Lol watch it’s not a 366 they are pretty much useless IMHO
OkieFishMan
Certified Camping and Fishing Nut
Enid, OK
OkieFishMan
GMC C2500
454/SM465
In my case it was a Mark IV block, but I have a mechanical clutch so I need a block that is tapped for the pivot ball mount.
On any of them, for the money you spend buying pistons, turning the crank, resizing the rods, etc., you can buy a stroker rotating assembly already balanced for only a couple hundred more. To me picking up 30 cubes for a couple hundred bucks is a no brainer.
75Monza
K30, K20, K20
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
75Monza
K30, K20, K20
Trying to keep initial cost low, don't plan on paying more than $200 for a good short block, just not sure what the good/bad are between the mark 4, gen 5 and gen 6.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
They sell stroker kits for tall decks somebody on here is doing it I believe a newer member
OkieFishMan
Enid, OK
OkieFishMan
GMC C2500
454/SM465
You can find Scat stroker kits online for under $1500 new. Get internal balance too.
hiltijoe
ny
joe
custom delux
4 k total build haha good luck go big like honkey and I lol
75Monza
K30, K20, K20
What, don't think it can be done in the $4k range? I'm talking parts, not machine work. Only machine work I can't do myself is line bore right now.
81k1500
