What size press (12 or 20 ton) for automotive
TX87R10
The Internet
Txt
Well I need a press and there is a 12 ton for under $200 at harbor freight. There is a step up 20 ton as well but it's about $250.
For now I am just going to use it to separate the rotor and hubs so I can redo the brakes but I'd like for it to work every everything I may run across once I get in to the front suspension work. IS 12 ton enough or should I just nut up and get the 20 ton?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have a cheap 12 ton harbor freight press I bought probably 20 years ago. I don’t think I have ever needed more than the ram can provide. What I have needed is the additional “room” in the press.
For example, several years ago I needed to press the C-clip eliminators off my axles. The axles were too tall to fit into the press. On smaller things, I have had to get creative with stands and spacers because the area directly under the ram was bigger than the space between the bars.
I would agree, spend the additional money.
The Right side of Washington
Don’t think I’ve ever needed more than 12T except once. And front axle u joints in our old 07 Dodge took everything a 20 (25? Idk) ton press had in it to pop them loose. With heat!
Never seen anything like it….
Personally I’d get the 20.
shanegtr
Perth, Australia
Shane
R2500 Suburban
While its probably rare that you'd need the extra capacity, as others have said the bigger frame size can come in handy. I've got a 12t press in my shed and I've never maxed it out for capacity, but I have run out of physical room to put some things in it
I have a press I use this way more. It's too convenient.
Rickf
Grafton NH
1974, 1954 & a 1937
I eventually bought HF's air assisted 20T bottle jack for the press, it's a lot quicker than the hand pump. As an added bonus I've used the original to jack up my skid steer for installing winter chains and to prop up sagging floors in old houses.
TX87R10
The Internet
Txt
Yeah thanks everyone for the feedback. I found this 20% off coupon too good starting today. I think it will make the price close to the $200 mark if I use it.
I'm going to head up there tomorrow and see if I can find this 20T one
Don-T
Vermont
Don
I want to get the 20 ton press at HF they are out of stock in my area. I am going to wait for them to be available. I am not willing to try the 12 ton press. Hope you can get the 20 ton press where you are.
bajadiver
