What locker shall I go for?
Andreas Wickman
Sweden
Andreas
I drive a C20 1983 Silverado, 6.2 Diesel, 2WD TH700r4, semi-float 14 bolt 9.5 rear 4.10:1. I would like to rebuild the rear axle with the same ratio but with a locker. Can anyone who knows about lockers for this axle give me advice on what type and brand I should go for? All tips are very appreciated.
All the best from Sweden
tman
Stockton California
Tim
K1500
Hi , I drive a 74 GMC 4X4 and I installed a LA locker made by power Trax and off-road it's great.
Bennyt
Surprise
Ben
If a Detroit Locker is available, I'd go that route. Simple, strong, works incredibly well and lasts practically forever. Downside is that they can be a bit aggressive on a short wheel base as they wind up if you make a bunch of tight turns on street.
Zelph
Nevada
I would look to a limited slip/posi unit over a locker.
That diesel engine is not a tire shredder and being in Sweden, ice and a locker can make some awkward situations.
A Detroit trutrac will lock upon wheel spin but act open for all other driving.
Andreas Wickman
Sweden
Andreas
Wow, this Forum is just super. So much knowledge in one place. Great!
Were these trucks available with a locker as an option once they were ordered? If so, what type? It seems to be a different technology. Do the three mentioned above—Detroit Locker, Detroit Tru Trac, and LA Locker—all work with the same principle technology?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
What do you intend to do with the truck, and what are you expecting to gain from the locking differential?
There are lots of options out there, also some give and take from one style locker to another.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Originally these trucks could be had with the g80 “locker”.
I agree that a Detroit can be interesting on ice. I’d probably get an LSD for most street applications where maximum durability is not required.
I wasn’t a huge fan of my Detroit locker’s on road mannerisms.
I’m not sure if ARB makes an air locker for that differential, but I really like selectable lockers. Just make sure they get properly installed so nothing gets pinched or leaks.
Andreas Wickman
Sweden
Andreas
What I hope to reach with a locker is not to get stuck standing spinning on nearly flat ground - which easily can happen when it's slippery out in the fields during autumn/winter when the bed is empty and there is very little weight on the rear wheels. I'm a small farmer and the truck is my workhorse, all seasons.
Andreas Wickman
Sweden
Andreas
Dream should be a locker I decide when to engage. Is that possible?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Yes, it’s called a selectable locker. The can be electronic, pneumatic such or cable actuated.
You’ll need to check what’s available for your specific differential though.
Zelph
Nevada
The only selectable locker for your differential is an ARB part RD197
You’ll also need to purchase an air compressor to run it.
CalSgt
CA
Casey
If primarily being used on the farm a Detroit may be a good choice
Really? I didn’t search for any but I’d bet there are numerous selectable lockers for the 14 bolt, they are widely popular in the rock crawling crowd. I’d assume there is tons of aftermarket support in this area.
That said ARB is a great locker, I’m also a fan of the Eaton “E” lockers, my jeep came with Spicer’s E lockers front and rear and they have held up really well with no issues
Andreas Wickman
Sweden
Andreas
There seem to be a number of options. I have to gather the options and compare them. Once I'm done, I'll come back with my thoughts. Thanks a lot for everybody's input so far. It's beneficial to be a part of this community.
mattsk8
Michigan
I think a Detroit locker can cause as many problems in snow and ice as it solves. I would look at a TruTrac, but another option is putting chains on your back tires. Not sure what you're getting stuck more in, snow or mud. Unfortunately for snow it's tough to beat 4wd, I've never been glad I had a posi rear diff when I was driving in snow.
jwtlake
