What is this called?
Rusty Nail
Rusty
350sbc
Was missing the bolts that are found on the front of the spring.. was shaking and loose, making a rattle.
2.5" springs.
I bought 2 x 4 inch, 3/8 ×16 bolts and nuts.
How tight should it be? I assume tight enough to not work loose but not tight enough to cause a bind, but WTF is it? WTF does it do?
I only ASSUME the bolts were missing because jumping? Whatever.
When I tightened them to the above spec, the whole dealy got very stern and refused to budge. That's good , right? It's what I want fer sure, are there any adverse effects? What else just changed, if anything?
Driver side
Passenger side
Honestly don't know what they are called but mine has them too. The bolts are tight but not so tight that they bend the 'ears'.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’m thinking they are there to keep the spring pack aligned.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
X3 yup...they just keep the packs together so the individual springs don't spread apart.
chengny
Those are called rebound clips. They are designed to make all the leafs share the load - but only on those rare occasions when there is a downward load created by the weight of an unsupported axle - and not overload the main spring:
The leaf springs are normally installed with the band forward of the axle, but it is not something that has to be done that way. The steel band is called the rebound clip. Their main purpose is to help keep the main leaf from breaking on a rebound.
When the weight of a vehicle or trailer is on the spring, all of the leaves work together to support the spring above them. If the wheel drops for any reason the total weight of the axle falls on the main leaf if there are no rebound clips. The clip also keeps the leaves neatly stacked.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Top notch as usual:waytogo:
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
see. gm intended for you to get air in these trucks
SkreetKilla
