Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
My boy and I dropped the tank to swap the sending unit and pump. Then snatched the TBI off to add an adjustable regulator, gauge, pod spacer, rebuild and a TBI Spacer. As well as a fully open air filter with lid. After throwing it together I dialed up the fuel to 12.5psi and runs rather well. I am considering changing the injectors out and doing a grind on the ports. Will see how I feel at a later date.
Pic when you can. I was going to either put a connection or gauge underneath near fuel filter.
84_c10_GMC
Alex
Post up some truck pics. Heck, depending on the population of snooty people in your area, your truck will ridiculed much more driving it around than it will here. We have pristine trailer princesses, well almost, to rusted out tb shot trucks.
Don't be askeerd, we're truck people that enjoy trucks, so post 'em up.
Haha it’s not quite shitbox level. But I’m just trying to get it moving under its own power at the moment and then decide later on if I wanna throw an ls in it or rebuild another 350 and put back in it. I’ll try and get some pics today.
84_c10_GMC
Alex
Alright snapped a few photos before I run to orielly. Thing I hate the most is previous owner swapped the core support for the 88-91 front end…. I prefer the original 84. But it has a good grill and bezels so I may deal with that down the road. Need a couple front tires also and find my other center cap.
If anyone has or knows where to get oem style radiator supports for a 3 or 4 core oem radiator. Or something that will fit over this aluminum one better I’d appreciate it. Kinda have it Jerry rigged to hold it securely at the moment.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Funny we did the same thing with a shop light.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
So you mean the retainer cushions (rubber) for the radiator? Classicparts.com or once I figured out what I needed I got on amazon.
84_c10_GMC
Alex
More the entire bracket that goes across the top. My original brackets are about a half inch short of getting to the front of the new radiator. I got some larger rubbers to try and make work but I would have to cut the front lip off that holds the radiator in place for them to even attempt to work. So i just trimmed them down and sandwiched them between the radiator and oem to hold it. I’ll get a pic but I need the actual top rubber mount holders that bolt to the core support to be longer.
84_c10_GMC
Alex
Here’s a picture of what I’m trying to explain lol. Hopefully this shows it good enough.
Carb'ed Vortec 350
Maybe I'm missing something, but it appears to be held in just fine
84_c10_GMC
Alex
It is with a second rubber piece shoved under the main one. I need to raise the bottom of radiator up a touch. But with just the oem rubber and bracket. It comes down on top of the radiator tank and It does not hold the radiator in place. I have to double stack a trimmed rubber piece to make it secure. It works. But I’m not happy with it.
I think the problem is the radiator not the brackets,so you either need to source a different radiator,raise the radiator you have or make new brackets or modify the brackets you have.
mcarlo86
ND
Suburban
I ran into similar problems when I put an aluminum radiator in our '90 Suburban. I described what I did to make it work in this thread. Not the prettiest, but functional.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Did you have to buy new connections for your license plate lights? I can't seem to pull the plugs out of the black boots on my lights. Also can't seem to find new wiring for the female end of the connections. They are original so I'm sure they are just old and stubborn.
Nope. Just cut them, placed heat shrink over the wires, soldered, and heated up the heat shrink over the solder joint.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
As requested
Cool, I was trying to find a 30psi gauge. They seem to be 15 or 60. I was worried about potential leaks there. I see yours is 15?
crowe-t
