Big Ray
North Carolina
Ray
Nice! Dig the classic stock look.
Good part is, you have a Chevy and it seems like the 3/4 ton bow tie caps are the most plentiful and least expensive.
Front 4wd caps with the knockout are harder to find for sure. Dunno if yours is a 4wd or not. But out here in the land of a lot of clean Squares I hit up all the want adds for a year or more with no success for the front caps. Buddy found a set at the neighbors garage sale!
Found this joint. It'll be one of the last things I get.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Brakes seem to be a lot more important than they used to be!!!!
Flatwater
Nebraska Panhandle
Problem is, I still ain’t got ‘em! Short of monkeying around with the proportioning valve, everything has been touched. Finally have a good pedal feel, just no stopping. ‍♂️. I dunno. It’s cold, I’m pissed off. Going in the house to pout.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
well with the floor mat installed on to the door panels! I got some light gray suede to contrast the dark charcoal door panels, hope it turns out good! I used to old fabric as a template to fit the new stuff on.hope it works!!
350 w/203
Old/dark brake fluid?
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Do you have them adjusted right? I have mine adjusted just to rub the drum slightly when you spin the tire by hand.
350 w/203
Takes 2 to do this. One presses on the brake pedal while the other checks the hoses (3) for swelling.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Your adjuster is all the way in in that pic. Did you roll the adjuster out until you could feel it dragging? Might just not be adjusted right.
Johns C10 Hubcap
