Grumpy
Saskatchewan
Daryl
Myself, I would place the fuel filter before the regulator, as any restriction and associated pressure drop in the fuel filter is not controlled by the regulator AND the fuel going through the regulator is also filtered - contributing to longer life and accuracy.
Redfish
Prairieville, LA
Andrew
V1500
In my ongoing quest for perfection from the TBI 350 I decided to change the Knock Sensor. Just being honest, I didn't even know my engine had a knock sensor until a few days ago. I have been digging through this forum researching and reading and studying and while reading some stuff by @Vbb199 I learned about the knock sensor. So that gave me another lead to follow.
Stopped on my way home from work at O'Reilly's, spent $40 including tax and bought myself the biggest HorsePower Boost I have yet done to the Beige Unit. When I fired it up I saw my son's face change... Before I could accelerate slowly and gently into the upper RPM range but if I stepped into it aggressively the exhaust note would go flat, the power would fall off and I would basically make a bunch of noise with hardly any increase in speed. Now I feel like I am getting most of the advertised power from this old 350. I don't care if it is only rated for 210 HP, I just want it to give me what it is supposed to give.
I am pretty certain this was the original part:
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Oh yes, I've done alot of learning about the esc system, in conjunction with a knock sensor, and the ecms data and such.
I'm determined I will integrate an old school TBI esc system in conjunction with my holley efi, as a means to retard timing for when we put an 80mm on the big block and accidentally miscalculate cylinder pressures.
I'm currently in process of retrofitting an old school TBI distributor and its ignition module to play with holley efi also.
Love the simplicity of those systems !
Out of curiosity, what were you having trouble with ? Overly sensitive knock sensor ?
Grumpy
Saskatchewan
Daryl
I remember those knock sensors being VERY touchy if there was an exhaust leak nearby, or cheap shorty headers that would mimic a knock - then the timing would be retarded so bad the truck would drool and start eating all the green crayons.
Fun times at the dealership in those days.......
What's wrong with Green Crayons? They are GREAT, taste like green!!!!
Grumpy
Saskatchewan
Daryl
Never ate one. My Marine friend used to eat those first, so I had to settle for the bland purple ones..... still better than the silver ones (too much aftertaste.)
SirRobyn0
Rob
I assume that is directed at me. My thinking was if the regulator was to come apart the filter would catch it, but yea filtering first has it's benefits too.
Rebuilt the Hydroboost today, and powder coated the mounting plate, and master cylinder cover...Ultra chrome. Not as shinny as Chrome Plating, but looks pretty good.
dbush
Cheyenne, Wy
Dave
GMC K2500
Added some side boards today (I like to be a little different). That way if there’s a matching pickup in the parking lot I know which one is mine. That has never happened but you never know.
78C10BigTen
pennsylvannia
C10 BIG TEN
Mine had running boards when i bought it, i swore i was gunna tear them off! After using them to hold wrenchs, beer and using them to pull myself out from under the truck i grew to like them.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
First thing I did to my 75 was tear those things off.
  • Like
Reactions: WFO
SirRobyn0
Rob
You wouldn't happen to have a set laying around you'd want to part with then? They'd need to be shipped to me but we aren't terribly far apart. Not across the country any way. Well let me know if you have a set you'd wanna sell. Thanks.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Yessir, I've been wanting to sell them for quite a while. They're just sitting in the back of my parts truck now. They're undamaged and complete, and comes with all the hardware.
Heres a pic of them before I removed them.... and after.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Exactly when the knock sensors went out in my 2000 camaro SS it did the same thing. Glad you got it fixed it makes a huge difference. They reduce timing because they think something is broken in the motor. Lol
Oh what a difference a few hours make
Misty Blue
