SirRobyn0
Rob
@Scott91370 sold me his unneeded factory air filter housing, which I have installed on the truck. Previously it had a chrome air filter housing on it which the former owner had installed on it. I did like the look of the chrome, but I wanted to go back to factory. The truck looks very much factory so I'd just prefer to keep it that way. Plus the cold air intake that the factory housing has I see as a plus.
I gave the housing a quick cleaning and spray of glass black paint and it looks pretty good. Later when I have more time I put it in the sand blaster at work and get rid of that crap along the edge you can see in this picture, but for now it's just fine. It is sitting on top of an edelbrock carb, I'd kind of like to go back to a Q-jet, but the Edelbrock is working ok, so for now just leaving that as is.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Spent most of the afternoon just enjoying the day in 'the Cave" with "the Bear" on the radio listening to the top 500 rock countdown and finishing up cleaning the parts for my spare Holley carb rebuild. Having them soaking in Chem-Dip for over a month has removed most of the factory zinc cadmium finish and a little brushing has removed the rest. Then a good soak and spray down with brake parts cleaner thru all passages and then blown out with compressed air and now ready for reassembly. Will be upgrading the accelerator pump from 30cc to 50cc to give it a bit more juice when I punch it and to eliminate any hesitation it may have had previously! 1st pic was upon it's arrival a few months ago and 2nd of it's current state! :favorites13:
Along with a new rebuild kit will be installing all new brass floats, jets,etc!
78C10BigTen
pennsylvannia
C10 BIG TEN
What becane of the one i sentcha?? Lol
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
Got half the driver door blasted today before it got to hot. Triple digit heat in NorCal this weekend.
with such a small hose that looks like it'll take eons
Had a long day of about 100 miles, took it like a champ obviously but will be needing some power steering work (the pump leaks quite a bit, needs seals?)
I look at this pic and hear the tune from 'JAWS'.
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
you're totally right! haha i'll never be able to look at my bay at night the same way again
Camar068
10 yrs Air Force
ordered window motors for the donor doors. One was intermittent so I thought it best just to replace both. $35 each....can handle that....just want the damn things done and installed lol. Tired of ******' with em.
Got other **** to do.
Washington
Finally got a day to make some progress on the truck. Got the whole chassis, core support and underside of the bed painted.
1 step closer!
Powerhouse Ranch
3G Connoisseur
PA
Luke
1980 & 1988
C25 & V15
454 & 350
1 step closer!
what kind of paint did you use?
Curt
Loco Hills
Curt
K-30
I did the same.Ajusted the air/fuel ratio and the idle,and it runs just fine.Looks good man.
coffeeguy
