bluex
Spartanburg SC
C15
Damn dude, looks great, you killin me with this stuff. :drool:
Thanks! And sorry? :lol:
Well I couldn't sleep last night so I went out to the garage. About 2.5 hrs worth of work rewarded me with lower control arms without bushings! One of the inner sleeves is stuck on the cross shaft though but I will fix that tonight at work. Getting the bushings out really wasn't that bad, or maybe I just got lucky? If I would have had my sawzall it would have been quicker but a hacksaw worked just as good to get the outer shells out. Overall this project is going pretty well I just wish I had larger blocks of time to devote to it so I could wrap it up. Hopefully it will be done next weekend though....
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I haven't really "done" anything, but I am planning a custom A/C build for my 84' C10. Gotta do a lot more research, but I found a direct fit (mostly) parallel flow condenser designed for Squares from AC/Delco that should improve performance with R134a considerably. I'll also be going with a Sanden SD5 or SD7 compressor (AKA Sanden 508 or 709). These are pretty common aftermarket compressors, almost all the vendors use them. I'll be mounting it up with some Alan Grove brackets or making my own, depending on how hard it winds up being. One neat little trick that seems to help is running an orifice tube from an 89' Furd Thunderturd. Seems it has a smaller opening and really wakes up the AC system. I still need to do more research on that, especially on any potential negatives.
Jake_S
Charlotte, NC
350/SM465/NP208
Removed about 5lbs of dirt from the drivers side floor and took out what was left of the sound deadening material from the driver side as well.
Jake
cmull
Williamsbug, Va/Radford, Va
Colin
visited a local pick and pull and got new valve covers and steering wheel center cap! got halfway through cleaning up the valve covers before i had to go to work to pay for them.. haha
robert8096
Goose Creek SC
Robert
Picked up a used set of rims for a good price and decided to test fit them. The front needs to go lower but I will wait until the big block is sitting in there to make the adjustment.
Moderator Administrator
Those look decent :popcorn: What color will the truck be? I'm assuming black to match the rims or will you get a different set once it's painted? :)
robert8096
Goose Creek SC
Robert
Truck will either be a high gloss black or a bright yellow.
Codey
mulberry
codey
C-10 custom deluxe
put a new edlebrock intake on mine
caliphatman8123
Bakersfield, Ca
Sam
v1500 suburban
tbi 350
Nice install... looks clean
Sent from my MB860 using Xparent BlueTapatalk 2
Stroked
Beloit, Kansas
Jared
I did chengny's fix on getting my steering wheel straight. Just a quick turn of the adjusting sleeve. I didn't take a before picture, but it was off about 35-45 degrees clockwise. Muuuuch better! It was awful not being able to see half the gauges.
Sent from my iPhone 4s using Tapatalk
One of these days he'll finally come out of the closet and admit he likes little mirrors :rofl:
I know you're not talking about me !!! I don't put Revlon and Maybeline mirrors on my trucks.
bvandrey
