what fluid?
mistaake
SF Bay Area, California
Michael
Crown Vic
replacing gearbox in 77 suburban.
what fluid?
"power steering fluid"? or atf? or something else?
thanks
Georgeb
Wisconsin
George
K10 Burb Z71
what fluid?
thanks
What gearbox the steering gearbox?
Georgeb
Wisconsin
George
K10 Burb Z71
Power steering fluid. I would recommend you do a little flush of the pump bedor hooking it all up too.
Georgeb
Wisconsin
George
K10 Burb Z71
By the way thanks to your avatar everytime I see a red panda I think of square bodies!
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
So you have red pandas roaming the streets of Wisconsin or what?
Georgeb
Wisconsin
George
K10 Burb Z71
Yeah, like they are a nuisance around here. LOL! No, but at the zoo or randomly on facebook....
mistaake
Michael
Crown Vic
Red pandas are so cute :)
Shop will be doing the work on the steering stuff so I'm sure they will do it right whatever the correct procedure for bleeding/flushing system.
Just confirming one last time that I can use the following fluid? I'm a little paranoid because I don't want to have to replace the steering gearbox again.
_________________
1GKDT13S822244745O'Reilly Chemicals - Power Steering Fluid
Line: ORC | Part # 72805
Manufacturer's Defect Warranty
UPC: 33322728055
Universal Product
1 Gallon
Volume (Gal): 1 Gallon
DETAILED DESCRIPTION
O'Reilly Power Steering Fluid is specially formulated to meet the service requirement for virtually all domestic and foreign manufacturers' power steering systems. Meets performance requirements of GM9985010 (part number: 1050017), Ford ESW-M2C128-C and D, Chrysler MS-5931 (Hydroboost Systems), AMC 4125 (part number: AM 899332) and Saginaw.
Features And Benefits:
O'Reilly Power Steering Fluid helps maintain efficiency, performance, and the condition of power steering units. Designed to prevent leakage and squealing under severe conditions. Will not clog or foam. Helps prevent corrosion, oxidation and wear. For year round use.
O'Reilly Power Steering Fluid is formulated using select base oils and an additive package to impact anti-wear and anti-foam properties to the finished product. It is specifically formulated for use in power steering systems.
Delivers maximum performance.
Prevents wear and slippage.
Effective against foaming, oxidation, corrosion, and rusting.
MANUFACTURER INFORMATION
O'Reilly offers a complete line of automotive fluids and aerosol products for your aftermarket car care needs. Rigorous quality control testing ensures consistency throughout our product line - and dependability you can count on.
chengny
Hah. I thought that was a racoon.
JOD26
