Wanted: Good used 8.5" Limited Slip 10 Bolt 28 Spline
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I need an affordable limited slip for my 10 bolt 8.5" 84 K10 Front 28 spline axle.
With good bearings and races is a plus, that would save me buying a kit and a hydraulic press..
And after all I have read about the gov lock, I am quite sure I don't want one of those.
My gearset is 14/40 if the numbers stamped on the ring gear are correct.
I could also make use of two front axle spindles with nuts and washers for the outer bearing in very nice shape, mine are rusted and pitted bad. I already have bearing and seal kits from NAPA for spindles.
Shipping would be to 86320.
Thanks,
Kevin
Thunder
Colorado
D.
I've got a set from an '80. Matched front and rear complete with springs.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I found an affordable one in good shape on fleabay today.
It's on its way now.
Will shop around for shim kit and axle tube seals.
