Vince's TBI woes, progressive revelations, and tbi mods.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
The victim
Reset your IAC, and check the voltage at your CST. Check your TPS also.
Sent from my SM-A705U using Tapatalk
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I checked tps a while back, its fine i know i DO need to reset iac again tho.
After all the mods and timing adjustments, idle changed.
Its on my to do list
Vbb199
Salisbury NC
Vince
A lil' custom work
Vbb199
Salisbury NC
Vince
A little re-tappy tap to 5-40,
Old bushings snapped off, holes rebored to .500
Bronze bushings turned to .505 od, ID .375 for shaft and pressed in into holes.
Vbb199
Salisbury NC
Vince
Tada........
Vbb199
Salisbury NC
Vince
Not perfect, but good enough for today.
I also blended "VBI" so it looks like it belongs. ;)
Just need to make butterflies on wire EDM, and buy the police injectors and a new adjustable regulator.
Vbb199
Salisbury NC
Vince
Thanks to @1987 GMC Jimmy for reminding me, i can modify the factory pressure regulator and emulate the same affect as the 65psi police injectors.
Im going to proceed with that tomorrow, order a new gasket set, make a spacer for the larger butterflies, and then should i have time, install, and see how she roars.
Vbb199
Salisbury NC
Vince
The butterfly valves, done on wire EDM.
Vbb199
Salisbury NC
Vince
And the easy pressure regulator mod to make it adjustable.
I just replace that screw i drilled out with a 1/4-28 flathead
Vbb199
Salisbury NC
Vince
And done.
Vbb199
Salisbury NC
Vince
Other than losing my adjustable regulator setup after spraying my own eye with carb cleaner, and waiting on the gasket set i ordered... the 650cfm VBI is ready to transplant on.
ChevyJGP
