Vibration
Bigchev
Denver colorado
Arron
I have a 83 Scottsdale sitting on a 86 4x4 chassis with a 4" lift it has now developed a vibration? Any thoughts?
When did the vibration start? Gradually or all at once? What speeds does the vibration occur? Checked your u-joints and tires?
Bigchev
Denver colorado
Arron
I sold the truck two years ago to a buddy he replace a rear U-joint I'm trying to buy it back but not paying him what he wants since it has the vibration... I want to say I felt like it vibrated after 25mph and got worse... My buddy states it goes away after a certain speed? Only play I found was front drive shaft but that isn't spinning...
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Did he clock the yoke right?
Bigchev
Denver colorado
Arron
Not sure but he also installed new side gears or something in the diff possibly didn't set the pinion correctly?
PrairieDrifter
North Dakota
Mason
He shouldn't have had to mess with the pinion to do the side gears in the carrier, unless he did a ring gear and pinion.
Check diff fluid and maybe take the driveshafts off and see if there's play in the pinions
PrairieDrifter
North Dakota
Mason
by clocking it I mean when you take it off originally you should make a line with a marker or something and mark the one side of the driveshaft by the yoke and then put a line on the same side of the yoke as you marked the driveshaft, before you take it apart. Basically it can be 180 degrees off
But since it may be the wrong way you can mark the opposite sides then take it apart so you don't get confused
mattyb
