Valve Covers
87ChevyR10
Kansas
NA
NA
NA
Just curious, will the stock heads on my '87 350 TBI accept perimeter bolt valve covers? They currently have center-bolt style covers.
Thanks!
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Thanks!
No but you can get adapters, I have no idea how they work but I recall looking at them when I was working on my TBI small block.
87ChevyR10
Kansas
NA
NA
NA
I found a set by Jegs. It appears the adapters are held on the head using the center bolt mounting holes while providing perimeter bolt holes for the valve covers.
Product + Instructions
Sweet!
Ireally don't understand the vast price difference between the perimeter bolt style and the center bolt style. Seems ridiculous to me.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Eeewww... That means 2 gaskets per head... That could turn into a leaky mess. Any reason you really want the perimeter style covers?
87ChevyR10
Kansas
NA
NA
NA
yeah, they are usually cheaper
cbrodine
NW Ohio
Collin
C25
...not to mention there are ALOT more options for valve covers with perimeter bolt covers.
Driver4r
Nebraska
Trevor
k10,c20
Centered bolt valve covers were designed to disperse the tension of the bolts on the valve cover to prevent them from leaking as easy as the old style.
John81287
Mchenry,IL
V20
Cheaper isn't always better guys! Not that my opinion matters in the least but usually a design change is for the better. Not always but usually. As driver said.
Driver4r
Nebraska
Trevor
k10,c20
And most valvcovers you can get in both centerbolt, and perimeter.
da_raabi
FloriDUH
Adam
c30
Looking on ebay there are tons and tons of centerbolt options for under $100 new. That adapter you linked to was $150 on its own... Add in the cost of the valve covers and you are looking at over $200 for perimeter covers. IF IT WERE ME: I would get a set of fabricated sbc centerbolt covers for cheap and just go with it. If you want something special then go get them powdercoated for $20. You still haven't reached the price of the adapter plates... This way you spend way less and you have a virtually leak-free situation. Just my 2 cents.
87ChevyR10
Kansas
NA
NA
NA
I guess I need to do some more looking around then. Jegs has a a few options of which most are $150+. Then I see the perimeter type for under $100. I understand the difference, just not the vast difference in price.
da_raabi
FloriDUH
Adam
c30
Dude stay off jegs. You don't need overpriced name brand for a set of valve covers. There were a TON of used/new centerbolt covers on ebay for well under $100. Any design you like. Stamped, fabricated, chrome, black, ribbed, etc. Don't over think it and spend too much $$$!!!!
Or if you find a set of expensive name brand ones you like, then see if you can find them used on ebay, or search the part number and they may be cheaper new even. I do that all the time. Instead of spending over $35 on a belt I got the exact same brand/# belt on ebay for $14 shipped. Do some looking around, and try to stay away from the parts magazines, they over charge like a ****!
sparky77
