Valve cover gaskets.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I had a valve cover leak, last time I put the gasket on i did not have the yellow glue I usually use.
BEHOLD: Its yellow weatherstrip adhesive.
I wiped the oil out of the channel so the glue has something to stick too.
Just a thin bead around the parameter to tack the gasket in place.
Stick the gasket to the glue and let it sit for a while. Ensure your bolt holes line up with holes in the gasket and PRESTO! My Dad showed me this trick and I have used it since.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I forgot to mention its good for those cork oil pan gaskets as well.
I've used that stuff for years. One of the old timer guys I used to ask for advice way back in the day told me about that stuff. He calls it gorilla snot and it just about is. Its takcy but stringy and stretchy, so if you have to adjust a bit, you can.
I need to do something about the vc gaskets in the 454 too. They seep a little at times and I end up adding a qt of oil between changes now. Might get by with just retorquing though too.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Those cork gaskets are expensive over here. The rubber ones are cheaper.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Which work better?
I like the rubber ones better myself.
Plus that cork can be a real bitch to scrape off when you got to replace it.
I definatley prefer the rubber or neoprene. Not a van of cork.
Swims350
Logan WV
none
I'm a cork guy, always liked it and used it.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
The rubber ones were twice as much as cork, I like the old school appeal of the Fel-pro gaskets. I think they are being phased out like the oil pan gasket I just but on the big block dump truck. The silicone one was 50 bucks but its reusable and alot more convenient that the cork/rubber ******** normally used.
Swims350
Logan WV
none
lol yea I reuse the cork ones alot, others say they can't, others say they reuse rubber ones I never could, they'd always bust, or uh I mean split.
wilson79
